The front fascia under the bottom air intake is cracked all the way through and I think it will be easier to repair it than replace it although that is a thought.
Question; what kind of plastic is this and what glue do I use. The plastic/glue application information in the MM is more confusing than useful!
I presume it will need a compatible plastic backup doubler to hold?
I have plenty of experience with fibreglas but don't think it will hold to this plastic.
I may just end up using a wooden backer with screws since it is way down low out of sight.
Can heat be used to reshape this plastic where it is stretched? I've done a bit of plexiglas forming with heat which is a bit tricky also.
