I started with an intermittent problem where my Cruiser would not crank, not even a tic, tic, tic, tic. Then it became permanent.
I have confirmed the starter is working by jumpering the 2 pins in the starter relay socket.
I have totally disassembled the ignition switch but did not find anything broken or out of the ordinary. Furthermore, I have validated that the yellow wire on the starter relay socket is getting power when I turn the key in the ignition to start.
I can also hear the headlamp relay kick in to turn the off on starting.
I have tested and validated that the starter relay is working by 1) testing it on a bench with an ohm meter and 12 volt source, and 2) by swapping it with other relays.
I concluded that the issue was the PCM. I was getting a lot of error codes that all ended in "or PCM may have failed". I just got a reprogrammed used PCM that appears to be fine. All my error messages have gone away after powering it up and trying to start it a few times except one that relates to my low speed fan that I was previously aware of but did not interfere with the engine starting.
But the car still will not turn over.
Anyone have any other thoughts that may be preventing the starter from getting power that I have not tried?
