1 - 14 of 14 Posts
· Registered
2003 PT Cruiser pretty significant mileage but ran fine and was taken care of till this point, problem seems to be engine overheating, looking for advice on parts or a fix I’m missing, otherwise it would be for sale to someone who loves the car and would like to fix it themselves. great car was very reliable
· Registered
If you like the car then perhaps its worth keeping. As an owner with an original 2001 LTD 5sp my overheating was first caused by a crack in the plastic adapter on the top of the filler neck (can't remember what its connected to) but I could NOT see it. Had to use a pressure tester to find it. Then some years later I developed a pinhole leak in my radiation that allowed pressure to reduce causing overheating. Replaced the radiator. Now at 21 years old, 126K miles it runs and drive as it always has.
Good luck
· Premium Member
A couple of the simple reasons for overheating are, overflow hose is sucking air because of old age and very hard to detect, rarely do they leak fluid, but they suck air when cooling. Because of this, the overflow looks to have fluid in it, but the radiator itself is low, causing the overheating. With the engine cooled down, remove the radiator cap and top off the fluid. If it is low, that's the problem. I have had issues with the thermostat housing becoming corroded and slow leak there, usually just a little seeping and very minor leaking. Radiator cap itself not working properly, as in not holding proper pressure, can be a small issue, too. And also agree with the radiator fans not working properly.
· Registered
I had a 2003 PT that would overheat but not when AC was on. Turned out to be the fan. Ran fine after I replaced the fan unit. I went through the same thing on my 2007 PT, except with that one, I bought a defective fan unit. I replaced that one under warranty and it has been fine since. Both were non turbo.
· Registered
Definitely check that the fans work. I had this problem...in fact a mechanic messed me up...when working on my car...they did not put back in a fuse...and so the cooling fan did not run! So if the cooling fan is not working...start with the fuse, not with a new fan! Fuses are cheaper.
1 - 14 of 14 Posts
