Good Day to you all,
This van has had some wierd electronic stuff happening lately.
1. The air conditioning fan will work in all speeds and then suddenly stop. Adjusting the fan speed does nothing. Turn it off and come to a full stop. As I accelerate from the stop I turn the A/C on again and it works again. Seems to happen frequently on the hot days more than the cooler days. It's the wifes van and she uses the A/C all the time. I have replaced the fan itself and a multi fingered diode which was less than 1 foot from the fan.
2. A non start situation. Almost like it's not getting gas. After about 4-5 turns of the key (15-20 seconds each) it starts and bucks continuously. It drives real jerky (like its shifting but the shifting doesn't happen at the normal RPM ranges) then eventually drops down into limp mode and is like that until I disconnect the battery. I reconnect the battey and all is fine until the next time. It happened yesterday and approximately 1 month ago. I replaced the alternator because of a bad voltage regulator. When this happens, is there a way to read the thrown codes without a code reader?
Thanks,
Ken M
