Hi folks,
Starting a new thread from my Cylinder Head Cover Gasket discussion. ( Which when fixed led to a loose timing chain issue when testing )
I have pulled the Primary Chain Tensioner and it retracts but its binding inside. I've ordered a new one and will test to see if this corrects the loose chain.
I am wondering if it will apply the correct tension right away, without loading up with oil ??
Note: I haven't removed the timing cover in case this is the issue. That way I avoid all the extra work, hopefully ?
