I am a old gear head to put it plainly. This 4.7 is baffling to me. 2nd owner and too good a deal to pass up.At 200,000 I tore it down to install a new timing set and heads, the bottom end was good and the overall care the previous owner was impeccable. Here is my problem. She starts but runs rich, will not idle and dies after a min or two. Check plugs and most are covered in black soot, but not wet. I keep getting codes P0351,P0353,P0355, P0356,P0358. And while DTC present it will not restart. If I clear the codes and wait a min it will restart and after wiggling the wires on the previous cylinders with codes I will get sometimes No codes and other times different codes all dealing with then same issue-Coil related. I have done all the checking of voltages and ohm reading but find nothing wrong with andy coil packs. I have even switched the coil packs around. resulting in the same condition. I have been using the right plugs and clean injectors. electrical wiring is now exposed looking form shorts or chafed wiring to no avail. I have cleaned all connectors and plugins. checked and cleaned TPS, IAC MAP etc, etc. Everything seems to be functioning. Just not functioning at the right time.
When I put the new heads on, I made sure to have the pin on the cams as close to 12:00 as they could be in a relaxed position. I lined all sprockets according to instructions. to line up dark links in the idler sprocket window and install cam gears on cams, took a little effort and moved cams ever so slightly and assure you they were aligned right. or to the instructions. I might add I was at TDC # 1 cylinder. However, I am left to believe I was not sure whether I was in intake vs exhaust stroke. Can someone clarify if I am right, wrong or indifferent? I now realize I am getting too old for this kind of activity but refuse to accept the obvious answer. And by joining this forum and writing this is my way of asking for help. I have to solve this, cause my mind will not let me rest til I do. Thank you in advance for any responses I get. I have been reading a lot of other information elsewhere and have to say this forum seems to me to be the best, with real information a man can believe in I apologize if I have made any mistakes, this is the first time I have ever posted anything.
