Howdy guys,
It's been a while since I've been on the site. I posted a question about the infinity sound system a while back for this same car. This is a bit of an update and a question.
I have 2 questions;
First,we found out why the front speakers weren't working they aren't there. So we purchased new speakers. WHen we went to install them we found the speaker wires had been twisted together,hence we found that the amp is shot going to the front. The question is; can we buy any amp to replace it and hook the signal from the radio to the amp of our choice, or do we need to locate a chrylser amp for it????? We'd like to just purchase an amp of our choice but didn't know if it would work for the system.
Question # 2. we keep gettting the same O2 senor code with the check engine light and all 4 O2 sensors have been replaced. Mass airflow sensor has been cleaned, new gas cap, and new plugs. We were told that opening up the exhuast would probably help. What sugestions do you guys have for installing a performance exhaust on this car???? Can we modify the system with a header and a few high flow Cat's and install the O2 sensors in front of and behind the cats as it would be on the stock system??? Just curious. We are thinking that we have a bad cat in the right bank and if we're going to spend the money why not upgrade the exhaust system.
Thanks guys and hope to hear from you soon,
Vince
517-442-7764
I have 2 questions;
Vince
517-442-7764
