Well, my new son-in-law bought a pretty nice looking 2004 Mazda 626 with a 3.0 V6 automatic and it was smoking a little bit, and using a whole lot of oil (like a quart every 150 miles), so, since he and the daughter liked the car,I said, let's just do a quick rebuild of the heads, check everything else. He wanted to learn a little more about the mechanical side of things, so I said sure to an inexpensive build. Every piece in the engine has Ford stamped on it, so I thought not a really big deal. It turned out to be seized oil rings from the bad seals so it got completely rebuilt for that "learning experience in the end).
Got it apart, put back together, installed, and now the fun stuff begins. 14 years and 200,000 miles basically destroyed the layout of the wiring harness itself and this is where I need the help. I have to re-wrap and replace most of the wiring harness covers because of the heat damage, wires themselves are OK.
I know where all the sensors are, but a wiring diagram for the engine bay is needed. Last thing I want to do is get sensors plugged in wrong (some of the plugs are similar, and I need colors of the wires to ensure things get in the right order, like COPs and O2 sensors, along with most of the other sensors.
Can anyone help with this? A Haynes manual (rather worthless) does not cover engine bay. Much appreciated.
