Pull the plug wire for cylinder #3, if it has oil on it, you will need to replace the valve cover gasket and plug tube seals, then replace all the plugs and plug wires.
Tom
If your check engine light is blinking on and off, do not drive the car you will damage the cat converter.
Tom
