Welcome to Allpar.There is a 25 amp fuse #1 in the interior dash fuse block (not in the fuse/relay box under the hood) that supplies the multifunction switch through a Lt Bu/Or wire. You should have battery power at this wire at all times.
The headlamp relay is also on the same fuse block in the dash.
