2005 Jeep Grand Cherokee Preliminary Specifications
The information shown was released on April 7, 2004. All dimensions are in inches (millimeters) unless otherwise noted. All dimensions measured at curb weight with standard tires and wheels. See our main 2005-07 Grand Cherokee page!
FRONT AXLES
Differential Type Conventional (except electronic limited slip with NV245 transfer case, with Hemi)
Availability Standard on 4 x 4 models with 3.7-liter and 4.7-liter engines
Ring Gear Diameter 7.9 in. (200mm)
Axle Ratios3.07:1 - V6; 3.73:1 - V8
REAR AXLES
DifferentialRing gear diameter 8.3 in. (213mm). See front axle for ratios. Progressive differential optional on 4x2. Electronic limited slip differential standard on Hemi, optional on 4.7 with Quadra-Drive II.
ELECTRICAL SYSTEM
Alternator160-amp (all engines except diesel)
Battery Group 65 maintenance-free 750CCA
DIMENSIONS AND CAPACITIES
Wheelbase 109.5 (2781)
Track, Front62.0 (1575)
Track, Rear62.0 (1575)
Overall Length 186.6 (4740.5)
Overall Width
(width at mirrors)
84.3 (2138.7)
Body Width 73.3 (1861.8)
Overall Height 67.7 (1719.6)
Load Floor Height 32.1 (843.5)
Sill Step Height 19.8 (502.7) 4 x 2, (512.5) 4 x 4
Chassis (Fuel tank) 9.5 (245.6)
Front axle8.5 (209)
Rear axle 8.0 (203.6)
Approach Angle 34.1º
Ramp Breakover20.6º
Departure Angle 27.1º
Frontal Area21.0 sq. ft. (1.95 sq m)
Drag coefficient 0.41
Aero12.1 (Cd x Cross Sectional Area)
Fuel tank capacity20.8 gal. (78.7-liter)
Front head room39.7 (1008)
Front leg room41.7 (1058)
Front shoulder room59.1 (1502)
Front hip room57.6 (1451)
Front seat travel10.6 (270)
Front SAE volume58.02 cu. ft. (1.6 cu. m)
Rear head room39.3 (999)
Rear leg room35.5 (901)
Rear shoulder room58.5 (1584)
Rear hip room60.6 (1539)
Rear knee Clearance1.44 (36.6)
Couple 33.0 (838.2)
SAE volume50.84 cu. ft. (1.4 cu. m)
Cargo VolumeBehind front seat: 34.53 cu. ft. (1.14 cu m)
With rear seat folded: 67.40 cu. ft. (2.00 cu m)
SUSPENSION
Front Short/long independent (SLA), coil springs, gas-charged, twin-tube coil over shock absorbers, upper and lower control arms ("A" arms), stabilizer bar
Rear Live axle, link coil-with track bar, gas-charged twin tube shock absorbers, stabilizer bar
STEERING
TypePower rack-and-pinion
Overall ratio15.8:1 - on center, 13.9:1 at full lock
Turning diameter 37.1 ft. (11.3m) curb to curb
BRAKES
Front
Size and Type12.9 x 1.2 (328 x 30) vented disc with 1.89 (48) two-piston pin-slider caliper and ABS
Swept Area282 sq. in. (1820 sq cm)
Rear
Size and Type12.6 x 0.55 (320 x 14) disc with 1.89 (48) single-piston pin-slider caliper and single-channel ABS (Three-channel ABS standard on RWD. Four-channel ABS standard on 4x4.)
Swept Area257 sq. in. (1658 sq cm)
Power Assist Type Single-rate, tandem diaphragm vacuum
WheelsCast Aluminum, Chrome-Clad Aluminum; 17 X 7.5 in
Fuel injection on all Chrysler engines is electronically controlled, sequential (one port at a time), and returnless (there is a fuel line going to the engine, but none returning - a system first used by Chrysler on the 1995 Neon). For more, see our 3.7, 4.7, and Hemi pages.
2004 and 2005 Jeep Grand Cherokee Engines
EngineCityHighwayHorsepowerTorque
4.0 I-6 (2004)1621195230
3.7 V-6 (2005)1621210235
4.7 (2004)1520235295
4.7 (2005)1420230290
5.9 (2004)1520265330
5.7 (2005)1421325370
3.7 liter PowerTech V6
AvailabilityStandard 4 x 2 and 4 x 4 Laredo
Displacement226 cu. in. (3701 cu. cm)
Bore x Stroke3.66 x 3.57 (93.0 x 90.8)
Valve SystemChain-driven SOHC, 12 valves and hydraulic end-pivot roller rockers
ConstructionCast-iron block and bedplate, aluminum alloy heads, balance shaft
Compression9.6:1
Power 210 hp (157 kW) @ 5200 rpm (58.1 hp/L)
Torque235 lb.-ft. (319 Nm) @ 4000 rpm
Max. Speed5800 rpm (electronically limited)
Fuel Unleaded regular, 87 octane (R + M)/2
Oil Capacity5.0 qt. (4.7-liter)
Coolant14.0 qt. (13.25-liter)
Emission ControlsDual three-way catalytic converters, heated oxygen sensors and internal engine features. Meets LEV II evaporative emission requirements in California, New York, Massachusetts, Maine, and Vermont and Tier I evaporative emissions and Clean Fuel Fleet Certification (CCF-LEV) in all other states. Meets Euro IV in international markets.
Gas mileage16/21 miles per gallon (estimated EPA).
4.7-LITER SOHC POWER TECH V-8
AvailabilityStandard 4 x 2 and 4 x 4 Limited, optional
Type and Description90-degree V-type, liquid-cooled
Displacement287 cu. in. (4701 cu. cm)
Bore x Stroke3.66 x 3.41 (93.0 x 86.5)
Valve SystemChain-driven SOHC, 16 valves, and hydraulic end-pivot roller rockers
Fuel InjectionSequential, multi-port, electronic, returnless
Compression Ratio9.0:1
Power230 hp (172 kW) @ 4700 rpm (50.0 hp/L)
Torque 290 lb.-ft. (393 Nm) @ 3700 rpm
Max. Engine Speed6000 rpm (electronically limited)
Fuel RequirementUnleaded regular, 87 octane (R+M)/2
Oil Capacity6 qt. (5.7-liter)
Coolant Capacity14.0 qt. (13.25-liter)
Emission ControlsDual three-way catalytic converters, heated oxygen sensors, internal engine featuresB
Gas mileage14/20 city/highway mpg (estimated EPA)
A. Meets LEV II evaporative emission requirements in California, New York, Massachusetts, Maine, and Vermont. Meets Tier 2, Bin 5 emission requirements and Clean Fuel Fleet Certification (CCF-LEV) in all other states.
B. 4 X 2 meets LEV II evaporative emission requirements in California, New York, Massachusetts, Maine, and Vermont. 4 x 2 meets Tier 2 Bin 9A emissions requirements and Clean Fuel Fleet Certification (CCF-LEV) in all other states. 4 x 4 meets LEV II evaporative emission requirements in California, New York, Massachusetts, Maine, and Vermont. 4 x 4 meets Tier I evaporative emissions in all other states and Clean Fuel Fleet Certification (CCF-LEV.) Meets Euro IV in international markets.
5.7 Liter Hemi V8
AvailabilityOptional - 4 x 4 Limited
Displacement345 cu. in. (5654 cu. cm)
Bore x Stroke3.92 x 3.58 (99.5 x 90.9)
Valve SystemPushrod-operated overhead valves, 16 valves, eight deactivating and eight conventional hydraulic lifters, all with roller followers
ConstructionDeep-skirt cast-iron block with cross-bolted main bearing caps, aluminum alloy heads with hemispherical combustion chambers
Compression Ratio9.6:1
Power 325 hp (242 kW) @ 5100 rpm, (57.5 hp/L)
Torque 370 lb.-ft. (502 Nm) @ 3500 rpm
Fuel RequirementUnleaded mid-grade, 89 octane (R+M)/2 - recommended
Unleaded regular, 87 octane (R+M)/2 - acceptable
Oil Capacity7 qt. (6.6-liter)
Coolant14.5 qt. (13.72-liter)
Emission ControlsDual close-coupled 3-way catalytic converters, Quad heated oxygen sensors and internal engine features. Meets LEV II evaporative emission requirements in California, New York, Massachusetts, Maine, and Vermont and Tier I evaporative emissions and Clean Fuel Fleet Certification (CCF-LEV) in all other states. Meets Euro IV in international markets.
Gas mileage14/21 estimated EPA gas mileage (mpg)
Transmissions and transfer cases
Both New Venture transfer cases have an electronically controlled clutch-pack torque transfer type center differential, and a front-rear torque split of 48/52.
The single-speed NV140 is included with the V6 and has full time four wheel drive.
The two-speed, electronically shifted NV245 is included with V8s. The low range ratio is 2.72. Operating modes are 4x4 low (lock), neutral, and full-time active 4x4.
For more transmission details, see the main Grand Cherokee page.
2005 Jeep Grand Cherokee Transmission Ratios
Gear3.7
(Mercedes)
4.7 and Hemi
(Chrysler)
13.593.00
2 primary2.141.67
2 alternate1.50
31.411.00
41.00.075
50.830.67
Reverse3.163.00
Final Drive3.07:13.73:1
Overall Top
Gear Ratio
2.55 with 3.07 axle
2.95 with 3.55 axle
2.50 with 3.73 axle
Production
The 2005 Jeep Grand Cherokee was produced at the Jefferson North Assembly Plant in Detroit, starting in the third quarter of 2004. Assembly for markets outside North America began in the first quarter of 2005 at the Magna Steyr assembly plant in Graz, Austria.
Jeep Grand Cherokee at Allpar
