1 - 6 of 6 Posts
I have a 2005 that gets wet inside the passenger front door everytime it rains. There is a drip where the top dash meets the air bag cover. Last night I caulked both rubber seals and a gap around the top of the windshield but it is still leaking. Any suggestions? Thanks!
Discussion Starter #4
No sunroof. I took the trim piece that runs to the right of the windshield and found the water coming from the top of that trim piece but cannot see where the water originates. Probably will stuff some cloth in the grooves of the trim and hope it will slow the leak.
With the trim piece off and a helper, run a garden hose stream at low pressure around the area outside the vehicle to see where the water is coming in. Is it entering at the top of the windshield weatherstrip?
Cars often rust out in that corner behind the trim, eventually showing up as a scab at the corner of the windshield on the roof. Sometimes just from trapping water; often from a windshield replacement where they sawed through the gasket material with that razor wire and scraped to the bare metal, then did not do any touch-up with paint. The latter was my case, my body shop owner told me, and he fabbed new windshield channel, welded it in place, painted, and installed the new windshield (#6 for my 92 Dakota).
1 - 6 of 6 Posts
