I recently went to start my 2005 Pt Cruiser Limited and the instrument cluster was dead. It's never acted up before. Checked ALL of the fuses, all good. Cleaned the battery terminals and connection where the big red power cable mounts to the main fuse panel in engine bay, and applied some silicone grease. The cluster came to life once, then went dead again.
I suspect the alternator has failed, and that this is why the instrument cluster is not working.
Before I order parts, I'd appreciate your tips on what all to do while I have it apart, advice on how to go about it (anything different from what the service manual says) and if I should pay a shop to do the work instead.
It has 137k on it, and looks like the belts have never been replaced, so I'm sure it's long overdue for a new timing belt and water pump. I also have the two main engine mounts (already replaced the two strut type mounts).
The shop manual instructions for replacing the "generator belt" that say to check belt tension using Special Tool 8371 and a "DRBIII", whatever that is. So, it looks like proper belt tension is super critical and requires special tools. What ever happened to automatic belt tension? Is all this really necessary?
I've always done my own repairs, but am semi-disabled nowadays, so am considering having the work done. If I were to pay a shop, how much do you think it should cost me to have them replace the alternator and drive belt, and install the front-center and rear-center motor mounts? Add to that replacing the water pump, timing belt and idler pulley (is there more than one?)--how much should all that cost?
I may only be able to replace the alternator, drive belt and engine mounts for now. Anyway, the transmission seems to be going out (will see which symptoms remained after I replace the alternator), so I don't want to sink a bunch of time and money into this car just yet. I love this car, but am thinking it's time to move on to another beater. Problem is, I can't get a "new" car until I get rid of the Pt Cruiser.
Am wondering if there is ANY WAY to replace the alternator without removing the lower control arm and axle? Seems like it should be possible after I remove the heat shield and jocky the engine and trans around to make room.
