When turning the key on and observing the "bulb check" - neither of these are working. No check engine light, no ABS light. Pretty big bummer as without a working check engine light it will not pass TX emissions. If this were an older vehicle the obvious answer would be, pop the cluster out and replace the bulbs, but hey...as far as I know these are surface-mounted LED's on a circuit board, not individual little light bulbs - maybe I'm wrong on that and there are small bulbs in them similar to the climate controls, and they've simply burned out from being on forever due to faults, or a dishonest seller has popped them?
I did remove the cluster and have a look, and I don't see where anyone cut wires to hide the fact the check engine light might be on, so who knows? Any ideas?
I'm slowly getting this car together to where I think it's trustworthy; it's really not a bad car at all but has a few little hacks here and there I'm undoing.
Richard
Richard
