In September of 2019 I was cruising up I77 at about 70mph when after having stopped for a fillup about 10 miles before when NOTHING, shuts down completely, complete loss of loco motion. Pulled over to the side of the road and ended up being towed 201 miles home. The next day I did some checks for spark, fuel, OBD codes, etc. NOTHING, did some reading and decided it must be cam position sensor and/or computer. I installed the new CPS and NOTHING. Received a reconditioned computer a week later installed it and no change. (I did send it back and reinstalled the original) I then for some reason remember that it has a timing belt and pulled the cam top cover and bingo, no belt and figured this had to be the issue. (water pump was free spinning) I replaced the timing belt, idler pulley, tension adjuster/pulley, water pump and reassembled to the point that I could start it. NOTHING. I thoroughly checked for correct timing, tried again and NOTHING. I looked for information on whether the engine is/was an interference engine only to find conflicting opinions. I did compression checks and found little (30psi) to mediocre (90psi) compression on a couple cylinders. I did leak down test that were hit and miss. Both tests varied each time I performed them and where very inconsistent, anywhere from 8% to 29%. (even tried 2 different gauges) After some rumination I decided to pull the head to check for bent/damaged valve and after pulling the calves to check for concentricity did find some pitting on the seats and non-contact areas on the valves but NO bent valves. Had the head rebuilt, reinstalled and NOTHING. I went back and reinstalled/retimed it yesterday and NOTHING. I had purchased a crank sensor along with the cam sensor that I never bothered to install previously so I thought I’d try it. NOTHING. I went back through and checked/rechecked all connections that where disconnected while working on it. Funny thing is that now I don’t even have spark as before it at least spit and sputtered occasionally. The car only has 123k on it and is in great shape otherwise. I really hate to get rid of it but have a little cash and a LOT of time into it in the last 7 months. Plus a whole new suspension that was only about 6-8 months old when it went down. Won’t get anything for it in scrap, and I’d love to still be driving it but would also love the space that it’s been taking up in my garage. Really disappointed in this 05’ my first was an 01’ and the timing belt went when I replaced it when the water pump began leaking at 195k. That one died of unknown cause at 259k! Would anyone have any ideas on where I’d start from here after all that’s been done? I’ve never had my patience grown so thin as with this PT. Any suggestions and/or comments would be greatly appreciated. Thanks
