UPDATE:
The MIL turned off on it's own prior to any troubleshooting done.
Troubleshooting steps that have been taken so far.
Going to give it a week or so of normal driving then check for DTCs in the powertrain module and go from there.
- Tested Battery for health. Pre-start voltage, voltage drop during crank, and a load test. It passed all three. (battery rated at 700CCA tested at 615CCA).
- Tested charging system health. 14.4 V at battery nd 14.5V at alternator output.
- Removed battery and air box to inspect wiring.
- Two grounding points on the chassis, were inspected, removed, cleaned and reconnected testing for resistance and voltage drop across the connection.
- Battery terminals had light corrosion (white powder) and were cleaned.
- Transmission harness was inspected for damage. None found.
- Resistance readings and test for voltage drop checked from PCM/TCM connector to trans connector. (all voltage drop tests were done while wiring was static and during manipulation. All checks out.
- Found wiring repair done with scotch blocks to driver side High Beam headlamp. Will be checking system and properly repairing the wiring at a future date.
- Inspected TIPM for obvious signs of damage/failure.
