1 - 2 of 2 Posts
The entertainment system is nonfunctional, including not playing DVDs and not reading or ejecting CDs. Radio works fine. Scanner identified code B222B (“vehicle entertainment system internal”). Any recommendations?
Thanks for providing the fault code. The service information blames the DVD player. Erase the code if you can, try a battery disconnect/pause/reconnect to reset the logic and inspect the connections before condemning the player.
The player may be repairable or you could exchange it from an authorized Chrysler electronics repair depot that is local to you (SE US). I use United Radio in Syracuse, NY:
Repair and Remanufacturing | United Radio (at http://www.unitedradio.com/automotive-electronics/repair-and-remanufacturing/ )
B222B-VEHICLE ENTERTAINMENT SYSTEM INTERNAL
For a complete wiring diagram, refer to the Wiring Information.
  1. When Monitored:
    With the ignition on.
  2. Set Condition:
    The DVD Player detects an internal failure.
Possible Causes
DVD PLAYER
1 - 2 of 2 Posts
