L
link51
·Guest
My cruise control has stopped working. It shows it activated when I press the on button and then push the lever down to set it, but no cruise. I went to the engine compartment and checked the fuses and really do not know what fuse is for the cruise control. Still checked them all and they checked out ok. I removed the vacuum hose at the servo and definitely heard the air release in the vacuum line. Replaced the cable on servo thinking it was stretched but still no cruise. Is there a relay or something that I am over looking? I am also told there are no inside fuses on the left side on the 2006 or above PT Cruisers. I would appreciate any suggestions on this problem.
Thanks.
Thanks.
