2006 PT Cruiser with no power, won't start, no dashboard lights...
18K views 41 replies 7 participants last post by  AllanC
#1 ·
So, the other morning, I got in my 2006 PT Cruiser to drive to work. and it wouldn't start. Turned the key, and the dashboard lights came on, but that was it. No response from the engine. Turned the key again, and the dashboard lights flickered and then went out.
When I looked under the hood, I saw than the negative battery terminal cable connector had cracked and broken. Huh, I thought, never seen that before, but it should be an easy fix. I swapped out both the cable terminals for new ones, and...nothing. The dashboard lights don't even turn on, never mind the engine turning over.
I thought the battery must be dead, so I called AAA for a jump-start. The technician who arrived, however, said the battery had an adequate charge to start the car. He had no explanation for why the car wouldn't power up.
Any thought? All help would be greatly appreciated! My next step will have to be taking it to a mechanic, and I can't easily afford that.
