Hi all,
I gave a 2007 Drand Caravan with electric sliding door and door locks. This vehicle has been modified with a lowered floor and in floor motorized ramp as a I am a wheelchair user. The system started failinf a couple of weeks ago. The tech from the modifier (www.rollxvans.com) came out and replaced a lot of the elctrical system for the modification. However it still doesnt work.
He has suggested, replacing the door latch which is obviously bad as it wont pull the door in when the door is almost shut. The control box is good as he switched them from side to side to check.
First, is there anything I need to know that is not in http://www.allpar.com/forums/topic/149288-2006-dodge-grand-caravan-sxt-door-open-light-comes-on/?hl=%2Bsliding+%2Bdoor#entry11338074http://www.allpar.com/forums/topic/149288-2006-dodge-grand-caravan-sxt-door-open-light-comes-on/?hl=%2Bsliding+%2Bdoor#entry11338074 and http://www.allpar.com/forums/topic/150908-sliding-door-stuck/?hl=%2Bsliding+%2Bdoor?
Also, in the midst of all this I got a check engine light with a trans-neutral-safety switch code and all the gear selector indicators are lit when the vechicle is in park. Is this likely a coincidence or am I looking at a major electrical system gremiln?
Any thoughts and suggestions would be appreciated!
John
John
