1 - 8 of 8 Posts
Hi All,
Passenger headlight went out. I changed the bulb, still out. Here's my troubleshooting list:
Switched bulbs, new bulb is good.
Checked fuses, both good.
Changed pigtail. No idea which wires were which except ground so did it the hard way and wired it every which way possible.
Bought voltometer.
Checked wires.
Took out working bulb and figured out which wire was high/low. Wired pigtail again.
Probed connection for bulb.
Switched bulbs again.
Started from scratch.
Wash, rinse, repeat...
NO LIGHT!
Help!!!!
Discussion Starter · #2 ·
Hi All,
Bought voltometer.
Checked wires.
NO LIGHT!
Help!!!!
Ugggg...just figured it out. The port for the 10a fuse has not voltage running through it. Fabulous.
Discussion Starter · #3 ·
Now I'm frustrated. Apparently it's not that. The ignition has to be in on position for that port to light up.
So still HELP!!
Welcome to Allpar. The headlamps are powered by the TIPM (totally integrated power module). It takes the place of the old fuse/relay box and is 'smart' electrical system management.
You may also have a switch or wiring problem.
The TIPM can store fault codes, maybe telling us why the right headlamp is being kept off. The TIPM will shutdown a circuit if it detects a short in order to protect the vehicle. A fault code may also tell us that the circuit is open.
The Vt/Rd is for the low beams.
The Wt/Gy is for the high beam.
The Bk/Pk is the ground. It has to be a a good connection to the body.
Discussion Starter · #5 ·
Can you test for these codes with the same device used to check engine/emissions codes?
No, they are not OBD2 codes. You would need an advanced scan tool to read them.
Wiring or connection problem? Look for varmint chewing and/or corrosion?
1 - 8 of 8 Posts
