2010 Journey 3.5 v6 r/t...alt and battery replaced in the last 6 months...still draining and after sit for a while will not start...as soon as power is applied to the booster ports it will start..NTB has checked the battery twice and it and the alternator check good...had also checked at oreilly but was from the ports and battery showed bad...NTB mechanic said dodge had an issue with the radio, which update is available or could be the box that houses the fuses and relays...I worked for napa for 15 years, not as a tech, but it sounds to me like a bad cell in the battery but NTB will not replace it...Was wondering if you had any clues on this issue.
