2011+ VM Motori 3.0-liter V6 Diesel Engines Used by Chrysler
Starting in 2019, the VM 3-liter V6 will have a new turbocharger with a low-friction bearing, low-friction pistons, a new injector nozzle, new piston bowl, and glow plugs with integrated combustion pressure sensors, to reduce emissions and increase efficiency.
Created in 1947, VM Motori was named after its creators, Claudio Vancini and Ugo Martelli, who built the first Italian diesel engine. It was air-cooled and had direct injection. Water cooled diesels arrived in 1974, but did not appear in regular production cars until 1979 - in the Alfa Romeo Alfetta. The first VM diesel in a Chrysler was in the Voyager, in 1992.
VM Motori started supplying Chrysler in 1992, with the Chrysler Voyager's diesel option; it was owned by Detroit Diesel at the time, spent some time being owned 50/50 by General Motors and Fiat, and is now entirely owned by Fiat. VM Motori currently powers several European Chrysler and Jeep cars, as well as (as of February 2011) the Chevrolet Captiva, London Taxi, and other vehicles. [See VM four cylinder diesels]
Two VM engines are currently used by Chrysler: the 2.8 (Wrangler, Voyager, and Cherokee) and 3.0 (Grand Cherokee, 300C/Thema.) The Maserati Levante and Ghibli also use this engine, with twin turbochargers and other tuning changes.
The A 630 direct-injection V6 diesel uses Fiat's Multijet II injection system. Developed with Fiat Powertrain, VM's new V6 diesel hits a peak 177 kW (240-241 hp DIN) at 4,000 rpm and 550 N•m (406 lb-ft) of torque at 1,800-2,800 rpm. This engine was originally developed for General Motors, for eventual use in European Cadillacs, but GM never used it.
The engine is capable of both transverse and longitudinal mounting with cooled EGR in the heads and a vacuum pump being an integral part of one of the cams. A 250 horsepower version is supercharged.
Early US-spec Jeep Grand Cherokees and Ram 1500s with this engine tended to have SCR catalytic conversion system problems. These issues were resolved by February 2015; some needed recalibration, some needed new converters.
Fuel economy for the 3.0-liter diesel engine (as used in the Grand Cherokee) is 8.3 L/100km on the combined cycle, an improvement of 17% over the prior diesel. CO2 emissions (combined cycle) are 17% lower, at 218 g/km, partly a result of new 2000 bar injectors (Chrysler Europe claimed 1800 bar pressure, but this is likely on the lower power version).
RVC pointed out that the A630 V6 is used on European Chrysler vehicles; the Jeep Grand Cherokee and Ram 1500, as sold in North America, have been modified to deal with lower-quality fuel and stronger emissions rules, and carry the code L630.
In 2012, VM announced that the engine would be upgraded to meet the Euro 6 emissions standards in 2015, and that the Cento plant would be expanded to support much larger production volumes with the sale of their engines in Ram and Jeep vehicles in North America.
VM Motori A630 V6 Engine Structure and Features
The diesel engine uses a strong compacted graphite iron block with aluminum heads and a two-piece structural aluminum oil pan. Bore is 83 mm (3.27 in) and stroke is 92 mm (3.62 in) for a total displacement of 2987 cm3 (182 in3). Bore spacing is 96 mm (3.78 in).
The engine is compact and lightweight, with overall dimensions of 695 mm (27.36 in) in length, 729 mm (28.7 in) in width and 697.5 mm (27.46 in) in height. Fully dressed, it weighs 230 kg (507 lbs); on its own, it is 220 kg (485 lb). The engine was designed for either transverse or longitudinal mounting.
The crankcase has stiffened construction, including a compacted graphite iron bedplate that provides a rigid carrier for the forged steel crankshaft, cuttng noise and vibration. The oil pump is a rotary vane type.
The oil pan was reinforced for off-road use; the crankcase capacity is 7.7 L (2 gal). Pistons are cooled with the aid of oil jets; exhaust gas recirculation is water-cooled.
Chain-driven, dual overhead camshafts drive four valves per cylinder, through finger followers. Intake valves measure 28 mm (1.1 in), and exhaust valves are 24.5 mm (0.96 in) in diameter. Combustion-chamber volume is 24.68 cm3 (1.51 in3).
A forged-steel crankshaft is supported by four main bearing journals fitted with four-bolt main bearing caps incorporated into the bedplate. Externally balanced, the crankshaft measures 442.2 mm (17.41 in), reducing the overall packaging requirements of the engine. Connecting rods, with an overall length of 162.9 mm (6.41 in), are constructed of cast iron.
2010 Mercedes | 2011 VM A630 | |
Horsepower | 215 | 241 |
Torque | 376 | 406 |
L/100km | 9.7 (?) | 8.3 |
3.0 L V6 (24V) | EU Grand Cherokee | Grand Cherokee, Ram 1500 | RVC wrote, "The first concept RA engine was presented in 2004. GM's heads had similarly sized intake and emission valves, placed at an angle, while Fiat had different diameter valves, parallel to each other." |
Power: kW (hp) | 140 (190) | 184 (241) @ 4,000 |
