2012 Jeep Grand Cherokee SRT8 Specifications and Capacities
The 2012 Jeep Grand Cherokee SRT8 runs from 0-60 mph in 4.8 seconds, screams from 0-100-0 mph in the mid-16 second range, covers the quarter mile in the mid-13 second range, has a top speed of 160 mph, and brakes from 60-0 mph in 116 feet.
The engine has 16 pushrod-operated overhead valves, with sodium-filled exhaust valves and hollow stem intake valves; they are actuated by 16 conventional hydraulic lifters, all with roller tips. The fuel injection is sequential (each cylinder is uniquely controlled) and returnless (there is no return feed for excess fuel), and the engine has a Fuel Saver (cylinder cutoff) mode. The engine itself has a deep-skirt cast-iron block with cross-bolted main bearing caps, topped by aluminum alloy heads with "hemispherical style" combustion chambers.
Engine
Bore x Stroke
4.09 x 3.72 (103.9 x 94.5) - 392 cubic inches, 6.424 liters
Compression Ratio
10.9:1
Power (est.) (SAE J2723)
470 hp (351 kW) at 6,000 rpm; 465 lb.-ft. (630 N•m) at 4,300 rpm
Max. Engine Speed
6,400 rpm (electronically limited)
Fuel and Oil
Premium 91 octane (R+M)/2 - recommended; 5W-40 synthetic oil
Mileage
12 mpg city, 18 mpg highway (EPA figures)
Assembly Plant
Saltillo Engine Plant, Saltillo, Mexico
Four wheel drive
Transfer Case
MP3010 Single-speed, electronic proportioning (full time 4WD)
Torque Split, Front/Rear
Variable - 50/50 Snow and 35/65 Sport and Track
Front Differential
Conventional
Ring Gear Diameter
7.7 (195)
Rear Axle
3.70:1 ZF Electronic Limited Slip Differential (ELSD)
Ring Gear Diameter
9 (230)
Gear Ratios
3.59, 2.19, 1.41, 1.00, 0.83; reverse, 3.16
Approach Angle, Degrees
18.45
Ramp Breakover Angle, Degrees
17.84
Departure Angle, Degrees
21.9
Minimum Ground Clearance
8.3 (210.8)
Other specs
Alternator
Standard 220-amp
Battery
Group 65 maintenance-free 750CCA
Drag Coefficient
.39
Aero CdA
12.2 (Cd x cross-sectional area)
Front/rear weight distribution54/46
Gross weight rating6,500 lb (2,948 kg)
Curb weight (with full fuel)5,150 lb (2,336 kg)
Payload1,350 lb (612 kg)
Standard Tires
P295/45ZR20 Pirelli Scorpion Verde - All-Season Performance (run flat)
Optional Tires
P295/45ZR20 Pirelli P-Zero - Three Season (run flat)
Axle ratio3.70
Max towing5,000 lb (2,269 kg)
Jeep Grand Cherokee at Allpar
Trucks/SUVs
Jeep
Ram
Military
2015-2017
Forums
