2012 Pentastar 3.6 / 8spd into 2009 NITRO
1954 Views 1 Reply 2 Participants Last post by  Sir Moses Wellington
Seriously looking at this Swap -
Will the Dashboard - Cabin Modules - AC - Radio
talk nice with the 2012 PCM / ECM / TCM ?
Replacing gauges with those of Donor
which do not resemble NITRO gauges
at all gives one pause.
1 - 2 of 2 Posts
Will the Dashboard - Cabin Modules - AC - Radio talk nice with the 2012 PCM / ECM / TCM ?
Replacing gauges with those of Donor which do not resemble NITRO gauges at all gives one pause.
With how complicated engine swaps can be, it would probably be a lot easier to work a bunch and buy a vehicle with a 3.6L in it already, if not cheaper as well. It's hard to say, it might work right, but I doubt the 8 speed will fit without cutting and adjusting the transmission tunnel and the motor mounts will also have to be fabricated. I'm sure the wiring harnesses will not interconnect at all, just with how complex they are anymore. You might get it to run, but all the odds and ends might be far harder to get working correctly.
1 - 2 of 2 Posts
