If you're going to do all of #3 & #4, do you plan on doing the thermostat too?
While Mopar is always recommended, if you feel more comfortable choosing another brand (Such as AC/Delco as you mentioned), that's your prerogative. I'd rather go Mopar if I could afford it.
Also, unless you or your mechanic deems the upper oil pan as needing replacement, I don't really get the idea to replace it? The lower is steel and it easily rusts, the upper is aluminum and if the mating surface can't be cleaned off well enough to reseal, or it somehow became warped, I (personally, others may find or offer a better reason) don't see a need to replace it.
If you're replacing the oil filter adapter because it's plastic, does that mean you're going to a metal housing from Dorman or an alternate company, or do you not trust the one on either motor and just want a fresh one?
