So I have a 2013 dodge dart 1.4 turbo Rallye. This all started coming home from a trip. All of the sudden the car lost power. Got it to a safe place and checked codes. I had a cam sensor code. So I replaced the cam sensor. Twice. Did nothing. Code was still there. Took it to a dealer thought maybe it had to be programmed. But after 400 dollars they said that it don't need to be programmed. As I was trying to drive it on a dolly it wouldn't go on because of lack of power. At idle it stalled. When tried to start it there was no compression. So as I know about cars. My first thought was timing belt. Got it back to the shop. Bought timing belt and timing belt tools. But the timing belt was fine. I changed it anyways. Since I had the battery unhooked all codes reset. But now I have code p1523-00. And when I do a cylinder leak test every cylinder leaks in the intake. Also have code for transmission shift needs learned. Dealer couldn't do that either. States car wouldn't let them.
