1 - 6 of 6 Posts
Hey guys,
I have a 2013 Dodge Journey SE that seems to only overheat while idling but goes back down while on the gas and in motion. What could be the issue? I check my coolant levels everyday and they are good.
Thanks for your help!
Hey guys,
Ensure your radiator cooling fans are operational. At idle, they may not be operating - causing the overheat. Also ensure there is nothing blocking the airflow behind the grille opening.
When driving, there is often enough ambient air forced through the a/c condenser and radiator to keep the engine cool. When you stop, the airflow stops.
The radiator fan should come on once the engine is warm - and the a/c supplemental fan should operate when the engine is very hot - or the a/c is turned on.
It MIGHT be something as simple as a blown fuse or relay. You'll need to take a look and do some detective work on the cooling fans.
It may not be the case but one other thing that causes this is dirt n' bugs blocking airflow, sometimes you can only see a part of the rad and the bottom/side are plugged up. Every year at the ending of summer I always take my grill off and clean the rad's very well. The areas where regular washing doesn't get too.
1 - 6 of 6 Posts
