2014-2017 Fiat 500L and 500L Living: Serbian 500 on a Punto Chassis
The 2014-17 Fiat 500L is a five-passenger, four-door crossover similar to the Mini Countryman. Read our Fiat 500L driving test / review.
A seven-passenger version, the 500L Living, appears to be limited to Europe.
The Serbian-made 500L uses a lengthened and widened Punto chassis and is not based on the actual Fiat 500. The "L" stands for "leveraging," according to Fiat - large, loft, lifestyle, and light - though most people would be excused for thinking it stands for "Large" (it might - PT never really stood for "Personal Transportation").
This will be the first Eastern European car sold in the United States since the ill-fated, Fiat-based Yugo. Fiat has made major gains in quality from its Serbian plant, and the car is expected to live up to current Fiat standards.
Jim Choate wrote:
Even with the seat jacked up in height, there was still loads of headroom for me. Put sliding doors on it and it's a mini-minivan. It was very easy for me to get in and out of both the front and rear seats, the overall ergonomics were good, about the only issue might be the "split A-pillar," but I would imagine it wouldn't take long to get used to that. It has decent space in the cargo area that includes a PT-like shelf.
Fiat 500L Living
The 500L Living is longer than the closely related 500L by roughly eight inches, to provide seats for two more people. Styling is nearly identical to the 500L, with the main differences being more sheet metal and glass behind the doors.
The 500L Living has three rows of seats, and is the most compact seven-seater in its segment at 171 inches long, 70 inches wide, and 66 inches high. At launch, it will be available with Fiat's 95-horsepower 1.4 liter FIRE engine and a 105 horsepower TwinAir turbo for gasoline lovers, along with 85 and 105 horsepower Fiat diesels. The 85 horsepower 1.3 liter diesel is sold with an automatic.
See our Fiat 500L test drive
The 500L Living comes in Pop Star and Lounge editions, both with five or seven seats; there are eleven two-tone paint combinations and eight solid colors with six interior trims and numerous wheel/hubcap choices. It has available leather, navigation, and rear camera, and will be made in Serbia (Kragujevac). .
Fiat 500L Powertrain
In North America, the new Fiat has the 160-horsepower, 1.4-liter MultiAir Turbo engine and two six-speed transmission options, a dual dry clutch automatic or a manual; the engine and transmissions are essentially the same ones used in the Dodge Dart. The little 83-cubic-inch engine pushes out 184 lb-ft of torque.
A forged-steel crankshaft has lightened counterweights to reduce overall mass for high engine RPM operation. Lightweight forged-steel connecting rods have a unique cross section to minimize longitudinal and lateral bending. Lightweight cast-aluminum pistons and a 9.8:1 compression ratio improves the reciprocating assembly's efficiency. Full-floating piston pins increase strength; piston cooling jets at the bottom of each cylinder help improve fuel economy.
The six-speed transmissions both have a 6.88 ratio spread and final-drive ratios of 4.12 (manual) and 4.44 (DDCT) for quick acceleration, faster top speed, and a maintained fuel economy; first-gear overall launch ratio is 18.4:1.
The European version has a 95-horsepower 1.4-liter and a 6-speed manual transmission; the 85-horsepower, 1.3-liter MultiJet II diesel; and the 105-horsepower, 0.9-liter TwinAir two-cylinder with 6-speed manual transmission. The diesel includes a stop-start system for even higher city mileage, and has an optional MTA Dualogic transmission. Fiat claims a combined 67.3 miles per gallon (4.2 l/100km) for the 500L diesel.
The North American Fiat 500L comes with the same powertrain as Dodge Dart, tuned somewhat differently, and is rated at 25 city, 33 highway with the manual and 24 city, 33 highway with the automatic.
The North American Fiat 500L's standard power and torque both beat Mini Countryman and Kia Soul.
Suspension, Brakes, and Steering
A MacPherson front-suspension design has a rigid, tubular anti-roll bar for increased cornering performance and reduced weight. A "split-type" shock-absorber mount improves shock-absorber efficiency.
A torsion axle structure with a high level of rolling rigidity saves the weight of an anti-roll bar in the rear. Urethane bushings will improve ride control, comfort, and durability. Monotube shock absorbers are in the rear.
Single-piston, 2.24-inch brake calipers are on the front, paired with 12-inch vented rotors; 10.4-inch solid disc brakes are on the rear with 1.49-inch rear calipers.
An electric power steering system, which cuts maintenance, improves reliability, and increases efficiency, also controls oversteer on low-grip surfaces. The four-channel stability control system allows individual wheel braking and provides backup braking if one of the brake circuits failes; it also includes brake-force distribution, rollover prevention, hill-start assist, traction control, and braking assistance.
Exterior
Elevent colors will be available, with the option of either a black or white "floating" roof (with a 20.7-square-foot dual-glass panel sunroof). Side door moldings will be body color and are available with chrome accents. Belt- and window-molding surrounds will be black. Glass A and D pillars offer nearly 360-degree views from the inside.
The 500L has bi-halogen projector headlights and honeycomb lower front-grille texture. Headlamps will have chrome accents with the "500" logo, and square-in-circular tail lamps are visible from the side profile. There are seven wheel designs ranging from 16 to 17 inches.
500L Interior and Storage
Powertrain, wind, and road noise have been isolated, helping the new Fiat achieve a 72% articulation index. The noise, vibration, and harshness (NVM) package includes a laminated acoustic windshield, body-cavity silencing foam, under-flush rolled-framed doors with triple seals, and acoustic wheel-well liners.
The upper instrument panel has color-matched exterior accents and vinyl-wrapped or painted accents. The thick-rimmed, three-spoke steering wheel will be available in leather and two-tone color options.
Fiat 500L​
Compared with 500​
Length163"23" longer
Width70"6" wider
Height65"7" taller
Weight3,203Over 800 lb heavier
Seven fabric and two leather options are available, along with 64 internal/external design combinations.
An Electronic Vehicle Information Center (EVIC) is on the instrument panel with trip, vehicle, and Uconnect system information. Five-inch and 6.5-inch touchscreen Uconnect systems will be available. Climate controls and the gearshift are easily accessible efrom the center armrest.
Fiat's eco:Drive app will be integrated in the 500L. It collects all necessary vehicle efficiency data and transmits it onto the five-inch touchscreen, which can also be transmitted to a USB memory stick. Vehicle performance (such as per trip CO2 emission levels) can be analyzed.
A Beats Audio sound system has six speakers, an eight-inch dual-voice coil subwoofer with trunk-mounted enclosure, and eight-channel amplifier with Beats Audio digital sound processing algorithm.
For storage, the 500L has a capacity of about 14 cubic feet, far lower than that of the 2015 Jeep Patriot or Compass. The rear bench seat can be slid forward nearly four inches to create additional storage. The front passenger's seat back can also be folded forward, and the elevated back seats can be double-folded. The trunk has three different level settings. 22 storage compartments are located inside, including a passenger-side recessed instrument panel cubby and covered glove box.
The 500L has a low, 26-inch cargo-lift height and recessed lower-liftgate area for license plates.
The 500L has seven standard air bags (including a full-length side curtain airbag), reactive head restraints, and in some models, a rear backup camera.
500L Models and Verisons
The European version of the 500L is available in Pop, Sport, Trekking, and Lounge versions with a five-square-foot fixed-glass "skydome" sunroof available. Overall length is 161.65 inches (4.1 meters).
The base Pop is surprisingly well equipped; running on 16-inch alloy wheels, it has standard air conditioning, body-color moldings, bright exhaust tip, heated power mirror with spotter, rear window washer, wiper, and defroster, power windows and locks, remote entry, projector headlamps, alarm, tire pressure monitor, height-adjustable front seats, rear 60/40 folding seats with tilt, tumble, and slide, body-color dashboard panels, tilt/telescope steering column, floor mats, Fiat/Microsoft touch-screen stereo, vehicle information center, six-speaker stereo, cruise, seven airbags, hill start assist.
  • The Easy includes a soft-touch dashboard, rear parking sensors, and manual climate control, and allows the purchase of options.
  • Sport adds 17" aluminum wheels fog lamps, body-color mirrors, center console, leather-wrapped shifter and wheel, AC outlet, rear-seat armrest, vinyl wrapped instrument panel, illuminated-mirror sun visors, heated front seats, satellite radio, dual-zone automatic temperature control, garage door opener, auto-dim mirror, and power driver seat.
  • Trekking adds unique wheels, different front and rear fascias with black accents, two-tone black and brown seats, painted instrument panel, wheel arch moldings, satin chrome accents, and black body-side sill moldings.
  • Lounge adds (to Sport) leather seats, rear park assist and camera, vinyl wrapped instrument panel, chrome bodyside molding and exterior mirrors, power driver and passenger seats, and premium stereo.
Fiat 500 (US)Fiat 500L
Horsepower101 hp 160 bhp
Torque98 lb-ft 184 lb-ft
Gas mileage (premium)31 city, 40 highway (manual)
27/34 automatic)
22/30 (automatic)
Built inToluca; engines from Dundee, MichiganSerbia; engines from Termoli, Italy
Length90.6-inch wheelbase; 139.6-inch length102.8-inch wheelbase; 167.1-inch length
Width x Height64.1 x 59.869.8 x 65.7
Ground clearance4.1"4.7"
Drag coefficient0.332 (Pop), 0.362 (Sport), 0.359 (Lounge)0.310 (Pop, Easy, Lounge), 0.320 (Trekking)
Weight2,363 to 2,434 (Turbo: 2,477)3,203 to 3,254
Front suspensionMacPherson, coil spring with twin tube shocks and stabilizer bar
Rear suspensionTwist-beam axle with coil springs and twin-tube shocks
Tires185/55R15 (Pop, Lounge); 195/45R16 (Sport)205/55R16 (Pop, Easy, Lounge); 225/45R17 (Trekking)
Front brakes10.1 x 0.86 vented rotor12.0 x 1.10 vented rotor
Rear brakes9.4 x 0.4 solid rotor 10.4 x 0.4 solid rotor
Swept area, F/R193 / 153 sq in345 / 233 sq in
Headroom F/R38.9 / 35.640.7 / 38.9 (40.2 / 38.3 with sunroof)
Legroom F/R40.7 / 31.740.4 / 30.7
EPA interior volume75.6 cubic feet121.1 cubic feet
Trunk9.5 cubic feet22.4 cubic feet (seats up)
https://www.allpar.com/cars/adopted/fiat/500.htmlFiat500Abarth500C500e500L500X VansReviewsFreemontForum
