1 - 6 of 6 Posts
I have always understood that trailer tongue weight should be 10/15% of trailer weight with 60/65% of trailer weight in front of trailer axle. My current 2002 Liberty has a factory installed towing package and is rated for 5000# with a maximum trailer tongue weight of 750# (15% of 5000#) and in 12 years I have never had a towing problem with my boat.
I notice the 2014 Cherokee manuel states that a factory installed towing package is rated for 4500# with a maximum trailer tongue weight of 450# (10% of 4500#).
Why is the maximum not 675# (15% of 4500#) allowing a larger cushion?
I use my Liberty to pull my boat (est. Gross Trailer Weight 3300/3400#) and am looking at the new Cherokee to replace my Liberty, but it needs to be able to tow my boat with the same ease as my Liberty. I understand limitations of GVWR, GAWR, & GCWR and realize I could be getting close with 4 adults in vehicle although this is not the usual case.
I'm concerned I could be getting too close to towing limitations with the Cherokee and would appreciate receiving your opinion, as I do not want to have any future problems.
I have surge brakes on my boat trailer.
KOG
Actually 10% tongue weight has been the exact recommendation for most U.S. vehicles for many decades unless you're using a weight distributing hitch. Some trucks with more rear spring stiffness than needed for decent ride can tolerate 15-20% tongue loads. European vehicles have always tended to have much loser tongue loads, 5% or less. Those numbers are for "bumper pull" stuff, 5th wheel and gooseneck rigs can run much higher tongue loads.
You may need to shift your boat a little to the rear on your trailer to get the tongue load down to 450lbs, but it'll tow fine.
Actually, with single axle boat trailers, the recommended tongue weight is 7.5 to 10%, so you should be good on that account.
Discussion Starter #4
Thanks for input. I don't really think my boat is over the 10% limit and I'm going to try and get it weighed before purchasing the new Cherokee to make sure I'm well within limits and keep my mind at ease. I purchased my Liberty specifically to tow my boat and wanted to replace it with the Cherokee but was having concerns with reduced towing and tongue weights.
It's always best to weigh your rig rather than trying to calculate it from various published weights. An amazing amount of stuff seems to make it onto a boat and it all adds weight.
KOG
Not to mention the fact that published weights are often completely out in left field. I've never known a car to be very close to its supposed curb weight.
1 - 6 of 6 Posts
