bought our 2014 Cherokee new in 2014. I installed a MOPAR factory hitch (bumper beam type), new bumper cover and MOPAR wire harness kit.
Things have worked well since. A while back i had some issues with the trailer wiring and wasn't getting any lights on the tailer. I disconnected the batter on the Cherokee for a bit to reset things and the trailer lites started working again.
last fall i wasn't getting lights again so i was poking around with my multi-meter to see if i had voltage and had a small spark and then nothing at all. ALL the Jeep lights work fine. no issues.
I presume i may have shorted something and blew a fuse.
SInce this was not put on at the factory none of the fuses in the fuse box for normal trailer towing accessories work.
so, does anyone know where the problem might be staring with what fuse should i check?
I've attached a couple sections of the installation manual that came with the MOPAR wire harness. Specifically looking at the wire in views 25 and 26 where you plug the wireharness wire into the plug under the drivers knee bolster. Nothing obvious in the owners manual or fuse box that would power this.
