Hi all...newbie here. I don't know if this is old news to you guys but, it's new to me. Check out the engine selection chart for the 2014 ram truck according to wikipedia:
Model Years Engine Power Torque 1500 2013– 3.6 L (220 cu in) Pentastar V6 305 hp (227 kW) 269 lb·ft (365 N·m) 2009–2012 3.7 L (226 cu in) PowerTech V6 215 hp (160 kW) 235 lb·ft (319 N·m) 2009–present 4.7 L (287 cu in) PowerTech V8 310 hp (230 kW) 330 lb·ft (450 N·m) 2009–2012 5.7 L (345 cu in) Hemi V8 390 hp (290 kW) 407 lb·ft (552 N·m) 2013– 5.7 L (345 cu in) Hemi V8 395 hp (295 kW) 410 lb·ft (560 N·m) 2014– 3.0 L (182 cu in) VM Motori A 630 DOHC V6 Diesel 250 hp (190 kW) 440 lb·ft (600 N·m) 2014– 6.4 L (392 cu in) Hemi V8 455 hp (339 kW) 475 lb·ft (644 N·m) 2500/3500 2010–present 5.7 L (345 cu in) Hemi V8 383 hp (286 kW) 400 lb·ft (540 N·m) 2014– 6.4 L (392 cu in) Hemi V8 450 hp (340 kW) 480 lb·ft (650 N·m) 2010–2012 6.7 L (408 cu in)Cummins diesel I6 (6-Speed Manual/Automatic) 350 hp (260 kW) 650 lb·ft (880 N·m) 2011.5–2012 6.7 L (408 cu in)Cummins diesel I6 (High Output 6-Speed Automatic) 350 hp (260 kW) 800 lb·ft (1,100 N·m) 2013– 6.7 L (408 cu in)Cummins diesel I6 (6-Speed Manual) 350 hp (260 kW) 660 lb·ft (890 N·m) 2013– 6.7 L (408 cu in)Cummins diesel I6 (68RFE 6-Speed Automatic) 370 hp (280 kW) 800 lb·ft (1,100 N·m) 2013– 6.7 L (408 cu in)Cummins diesel I6 (Aisin ASC69RC Automatic) 385 hp (287 kW) 850 lb·ft (1,150 N·m) Chassis Cab 2010–present 5.7 L (345 cu in) Hemi V8 (3500 Only) 383 hp (286 kW) 400 lb·ft (540 N·m) 2010–2012 6.7 L (408 cu in)Cummins diesel I6 305 hp (227 kW) 610 lb·ft (830 N·m) 2013– 6.7 L (408 cu in)Cummins diesel I6 (6-Speed Manual) 320 hp (240 kW) 650 lb·ft (880 N·m) 2013– 6.7 L (408 cu in)Cummins diesel I6 (Aisin AS69RC Automatic) 325 hp (242 kW) 750 lb·ft (1,020 N·m)
That 6.4 sounds pretty good!
Link: http://en.wikipedia.org/wiki/Ram_Truck
