2015 Jeep Renegade specifications, comparisons, and safety features
Main 2015 Jeep Renegade page (with off-road specifications)
All Jeep Renegades are made in the massive Melfi plant in Italy; they are a conventional design, with transverse-mounted front engines and steel unibodies. The front suspension uses McPherson struts with coil springs, a flat front steel crossmember, high-strength steel lower control arms (double-shell for 4x4, single-sheel for FWD), and a stabilizer bar. In rear, a steel cradle (isolated with AWD, but not with FWD) holds Chapman struts, high-strength steel links, coil springs, and a stabilizer bar.
Number are still preliminary. In the past, there have been errors in Chrysler specification tables.
Fiat engines have cast iron blocks with aluminum heads; Chrysler 2.4 engines (including the EtorQ) use high-pressure die-cast aluminum blocks and heads.
For details on the nine-speed (used by the 1.4 turbo, 2.4, and 2.0 engines), see our nine-speed automatic transmission page.
Wheels, steering, and brakes
Fiat 1.4 | 1.4 Turbo | 1.4 Turbo | 2.4 | 1.6 E.TorQ/Tritec | 1.6 Diesel | 2.0 Diesel | |
Available | Europe, Latin America | North America | All but North America | World | All but North America | Europe, Africa | Europe, Asia-Pacific |
Stop/Start? | No | No | Yes | No | No | Yes | Yes |
Cubic inches | 83.5 | 83.5 | <- | 144 | 97.5 | 97.5 | 119 |
Bore / Stroke | 2.83 x 3.31 | 2.83 x 3.31 | <- | 88 x 97 mm | 77 x 86 mm | 79.5 x 80.5 | 83 x 90.4 |
Valves | Belt-driven MultiAir II, 16V | <- | <- | SOHC 16V | SOHC 16V | DOHC 16V | DOHC 16V |
Compression | 10.0:1 | 9.8:1 (22 psi boost) | 10.0:1 | 10.0:1 | 11.0:1 | 16.5:1 | 16.5:1 |
HP | 138 @ 5,000 | 160 @ 5,500 | 168 @ 5,500 | 184 @ 6,400 | 108 @ 5,500 | 118 @ 4,000 | 138 @ 3,750 or 167 @ 3,750 |
Torque | 170 @ 1,750-3,250 | 170 @ 2,500-4,000 | 184 @ 2,500-4,000 | 177 @ 4,400 | 112 @ 4,500 | 236 @ 1,750 | 258 @ 1,500 or 258 @ 1750-2500 |
Redline | 6,500 rpm | 6,5000 rpm | <- | 6,500 | 6,500 | 5,000 | 5,000 |
Base fuel | 87; 91 preferred | 87; 91 pref. | 95 RON | 87 | E0 | B7 | B7 |
Max towing | 2,200 lb | None | 2,200 lb | 2,000 lb | 2,000 lb | 2,200 lb | 3,000 lb |
Built in | Italy | USA | Italy | USA | Brazil | Italy | Italy |
Sport / Latitude | Latitude 2.4 | Limited | Trailhawk | |
Size | 215/65R16 | 215/60R17 | 225/55R18 | 215/65R17 |
Tire | Continental CrossContact LX Sport | GY Eagle Sport or Kumho KL33 | GY Wrangler SRA or Falken Wildpeak |
