2018 Jeep Wrangler JL specifications and dimensions
The transmissions:
Ratios1st2nd3rd4th5th6th7th8thR
Manual5.132.631.531.000.810.72 4.49
Automatic4.713.132.101.671.281.000.840.673.53
Engines and transmissions are detailed on the main Wrangler JL page
Clearances and angles
Going off-road?
Rubicon (JL=2018+)JK 2-doorJL two-doorJK four-doorJL four-door
Running ground clearance10.2"10.8"10.2"10.8"
Approach angle (degrees)44.6°44.0°44.4°43.9°
Departure angle (degrees)40.6°37°40.7°37°
Breakover angle (degrees)25.5°27.8°20.9°22.6°
The two doors
SportSaharaRubicon
Running ground clearance9.7"10.0"10.8"
Approach angle (degrees)41.4°41.8°44.0°
Departure angle (degrees)35.9°36.1°37°
Breakover angle (degrees)20.3°21.0°27.8°
The four doors
SportSaharaRubicon
Approach angle (degrees)41.4°41.8°43.9°
Breakover angle (degrees)20.3°21.0°22.6°
Jeep Wrangler Curb Weights
The V6 2018 Wrangler JL's weight dropped by 200 pounds from the 2017 Wrangler JK.
Curb Weight*Two doorFour door
Wrangler Sport3,9554,200
Wrangler Sahara 4,345
Wrangler Rubicon4,1454,455
* For V6 automatic. Add 55 pounds for the four-cylinder or 15 pounds for the manual transmission..
Towing is up to 2,000 pounds with the two-door and up to 3,500 pounds with the four-door (may vary based on equipment).
Dimensions
Wheelbase: 96.8 and 118.4 inches
2018 Jeep Wrangler JL Inches/Cu.Ft.
Front head room, hard top40.7
Front head room, soft top42.6
Front leg room41.2
Front shoulder room55.7
Rear leg room35.7 (two-door)
38.3 (four-door)
SAE cargo volume, seat folded (four door)72.4
SAE cargo volume, seat upright (four door)31.7
Total volume (four door)150.4
Overhang (F/R)29.2 / 40.8
Track62.9
Length with spare tire166.8 / 188.4
Width73.8
Height73.6
Liftover height29.7
Cargo width x height at gate opening41.1 x 36
Load floor height30
2011-17 Wrangler specificationsJeep Wrangler JL
The 2018 Jeep Wrangler JL: suspension aluminum vs steelopen or fixed roof pickup
body engineering
weight, strength, and safetytransmissionsengines
