Alcus and I managed to get the dwell set on his '67 Dart and have it running at a reading of 40. Actually had to take the new points out and reuse the old set because the engine wouldn't run with the new ones. He got a rebuild kit for the carb and got that taken care of so now we need to set the timing. The engine is a little hard to start but runs fine when cold but as soon as it reaches operating temp it starts running pretty rough so we figured it may be the timing is off. In his owner's manual it states that the timing should be 5 degrees BTC or TDC with Clean Air Package. What is the Clean Air Package referring to? Also, would 5 degrees BTC be the mark on the indicator that is to the left of the little hole (when looking at it from the front of the engine)? The indicator looks like it is stamped with 'BEFORE' on that side but kind of hard to tell with these old eyes. One more question, when checking the timing, aren't we supposed to disconnect the vacuum advance hose? If we are doing this right the timing right now is reading about 5 degrees after TDC and we would have to remove the dizzy and move the adjustment plate to be able to get the timing where it should be. Our problem with this is that the engine has always ran fine until recently when Alcus started having the stalling issue when at idle so it doesn't seem like the timing would have been off that much and it running as good as it was before.
