Thank you!I believe that ATF+4 is used in the PTU (on the right side of the transaxle) and in the over-running clutch unit ahead of the rear carrier. The rear carrier itself should use 80W-90 hypoid fluid.
Go with your owner/service manual lubrication suggestions.
