Welcome to Allpar. Diagnosis first. Any fault codes? Do you have a fuel pressure gauge that you can connect and pin under a wiper blade to monitor fuel pressure while driving?
The TBI system should be around 14 psi up to '92. There was a transition to the Magnum TBI and pressure increased to about 40 psi.
Don't forget to rule out ignition system possibilities. Low spark voltage when opening the throttle will 'blow out the candles', so to speak.
You want this to be in 'acting up mode' while looking for the cause. Are the Champion RC12YC spark plug tips a tan/white color?
Is the spark from the ignition coil a nice blue-white and not an orange color?
Transmissions can kickdown harshly with engine torque output issues and open throttle. Get the engine issue solved before judging the transmission.
