No worries! Found the right size bolt and corrected the problem I was having. It's all good.slim slow slider said:I am in need of this long bolt that goes thru the mount near the thermostat housing in early 90's 3.3 engines. Let me explain further:
There is a bracket on the passenger right (your left) engine cylinder head that goes to the motor mount. There is a long bolt that goes thru, with a bolt on the other end. I do not have any idea how long it is. If you have a wreaked or junk vehicle with this engine, I could sure use the length of that bolt. A nut should not be hard to find, as well. Looks like the head size is 15MM.??
Any help on this Holiday weekend is deeply appreciated!
