PUtting new wheel bearings on the front of the 300M.
Have them fully Torqued per Timken instructions (180 ft-lbs) but the face of the CV joint does not contact the inner surface of the hub-bearing assembly (area where the splines are)
I'm pretty sure the splines are fully inserted.
I thought the CV should rest against the hub. Are they supposed to be?
Didn't look at old ones before I took it apart.
Thanks.
Thanks.
