Hi Steve18. Doing four disc and one pot master cylinder and having all that under the hood just means you will have more to lose when something with the brakes fails, which it easily may. Secondly, remember that disc brakes take a larger amount of fluid in order to stop being the pistons are much larger than the approximate one inch diameter, give or take, for wheel cylinders. Thinking in numbers terms, you are asking a brake master cylinder piston to push the fluid volume of the four wheel cyinders stock, into four single piston calipers that take 2.5 times the amount of fluid as a wheel cylinder. I physically don't think the master cylinder could push that much fluid in a single pump of the brake.
As a solution, the Hemi darts in 1964/5 had a master cylinder offset to make clearance to the 426 Hemi valve cover. This may be part of the solution, move the whole unit outboard a little extra. Personally, I would figure this out, the single pot master cylinders were scary enough with four wheel brake drums, disc will stop faster, sure, but having to pump them two or three times to get the fluid volume to hold would be scary almost every time, power brake booster or not.
