1 - 12 of 12 Posts
I will swap my old 318 to a 440 in my 1968 station wagon, I have a lot of questions, some of their was answer reading this forums. I know that I have to upgrade rear end to 8.75 if I had the 8.25 rear end, I was looking photos to identify my rear end, and I think the car has a Dana 44 rear end, I read that is a 8.5 rear end. It could be enough for an almost stock 440? thank you
What model 1968 wagon do you have??
Thanks
Randy
Your almost stock 440 have the same torq as an pepped one, torque is mostly a factor of displacement as long as you dont boost it.
- 7 1/4" wont cut it, its weak already behind a slant.
- 8 1/4" is fine if you dont use your 440, marginal but i works for calm driving.
- 8 3/4" is a good one but they are getting scarse to find.
- 9 1/4" is also a sturdy piece used up to 20..ish in trucks, its probably the best axle of the bunch unless you really need the capacity of a Dana 60. Its also an axle that nobody recognises for what it is so they are usually cheap.
- Dana 60 is a sturdy one..
Shortening a raer axle isnt all that difficult if you buy new driveshafts.
- i seriously doubts that you have a Dana 44 under there. The factory didnt use em..
Reactions: jormymex
Discussion Starter #4
Thank you for your answers, The station wagon is a 1968 dodge coronet, I forgot to say. In the rear end´s image it look more like a 7 1/4, but is not the same, definitly is not a 8 1/4, in other images that I saw in internet is pretty much similar to dana 44 (image below) Other important thing is that it is a mexican building coronet, and some times it has differences with US o Canadian made. I will post a photo of the rear end, when I can take one. Maybe the best option is go for the 8 3/4 in the future
A correct 8 3/4" is a bolt in but youy may need to either change the driveshaft or get conversion u joints . Actually its viser to get a correct drive shaft since they are sturdier. ( its quite easy to buy a kit and cut it to the right lenght and weld the yoke on it.)
Reactions: jormymex
Discussion Starter #7
Thank you all, about your advices, I will go to 8 3/4, but in a theoric question: The dana 44 can handle a Big Block? I searched in internet but I can´t found anything. I suppose no.
I don't recognize this axle assembly, anyone else??
Last time I visited Mexico I was impressed with many of the differences.
RWD Darts didn't have concave backlites like N/A Darts.
K Cars could have Turbo II Engines
Lots of cool things
Thanks
Randy
QUOTE="jormymex, post: 1085131245, member: 105741"]
there is a photo of a mexican coronet rear axle, not actually mine,.[/QUOTE]
Discussion Starter #9
In other photograph of these rear axle, the ring number is DANA 18426, I saw and its a dana 44 3.31. Unfortunately I can´t take this week a photo of my own differential.
A Quick search indicates that it can live behind a 440 and survive, but it looks like its a bit of a gamble.
1 - 12 of 12 Posts
