1 - 3 of 3 Posts
You also have a lot of components that are the same for the B block 361.383. and 400 that work. The differences are the crank, piston, rods, intake manifold, pushrods and accessory brackets. Whereas the cams, lifters, rocker assemblies, heads, valve and timing cover/timing set, oil pump, valve covers, are inner-changeable. Not a complete list by any means.
1 - 3 of 3 Posts
