The 727 never had a trans filter other than the one inside the oil pan. Both lines are on the passenger side of the case. In order to change the filter you have to drop the trans oil pan. You can also drain the torque converter because there is an 1/8th inch pipe plug (I think that's what it is) in the front of the torque converter.
