1 - 12 of 12 Posts
Hi there guys .I appreciate your support I have a 71 dart gt with a 440 original slant 6 car ...my horn isn't workin took wheel apart seems like no powe there any ideas where to start thanks again
First step, check all fuses.
On some of these cars, the wire in the steering column would fray and short out, blowing a fuse.
Also, jumper power to the horn anyway, to see if it is working.
At the steering wheel, doesn't the horn switch just complete a ground circuit? As in there is never any power going through the horn switch at the steering wheel.
The horn wire in the column grounds the horn relay. The column must be grounded to the dash/body in order to complete the circuit.
The horn relay contacts do the heavy work of supplying current to the horn(s).
The column wire, if shorted would blow the horn and not blow a fuse. Shorted horns may blow a fuse.
Discussion Starter #5
Thanks Bob love your daytona had to sell all mine now have the dart tried power to horns they work fine fuses all seem good ...the 6 bus fuses under dash
Discussion Starter #6
Thanks very much your right I didnt word it well it is a ground set up in wheel they make contact but no sound
Discussion Starter #7
Does anyone know where the horn relay is on a 71 dart? I might go there look ing to see if it has power
From the 1970 Dart/Challenger service manual on MyMopar:
"The horn circuit consists of a horn switch located in the steering wheel hub and a horn relay mounted in the passenger compartment under the instrument panel at the left kickpad".
It would likely be a 3-terminal cube. You should hear or feel a faint click inside it when pressing the horn button.
The manual has the troubleshooting procedures and wiring diagrams.
Discussion Starter #9
Thanks very much will go back out side after I eat my steaks lol thanks for the great help
Here is a link to a wiring schematic for your vehicle. Scroll until you find a reference for 1971 Dodge Dart. There are 2 schematics.
MyMopar - Mopar Forums & Information - Mopar Wiring Diagrams 1966 to 1971 (at http://www.mymopar.com/index.php?pid=27 )
In addition to the tips presented look at the wiring connector that carries the load side power from the horn relay to the horns. There is a connector at the firewall through which the load side power for the horn passes. This must be in good condition and not corroded and separated.
Discussion Starter #11
Thanks very much Allen didn't know we had diagrams on here totally appreciate it ...now I just got to figure out how to get to them for future reference. Thanks again you all are great! We are MOPAR!
Discussion Starter #12
Well guys found it. It was the relay in the drivers ide kick panel contacts were corroded. I would like to thank all who supported me on this quest. And will be on more to support others. Miss my turbos but glad to be back with a big block lol
1 - 12 of 12 Posts
