Pulling the engine without pulling the transmission is not that difficult in the C-body. A buddy of mine repeatedly had his big block out of his '72 Monaco without pulling the transmission.
There are about half a dozen bolts holding the engine to the transmission, four bolts for the torque converter, the starter, and possibly a couple of brackets underneath. Sizes are generally in the 1/2" to 5/8" range, but regardless are standard SAE sizes.
I'm not 100% sure of the motor mounts, but they're probably not too bad either.
BE SURE to support the transmission underneath if you pull the engine this way, a ratcheting strap or a comealong work well for this.
