1 - 5 of 5 Posts
67 Dodge A100 Van. Slips to the point of not drive able in All forward gears...Reverse is fine...
Is this happening after the transmission has had time to warm up? When was it last flushed? Has it had a band adjustment?
Common 727 issues:
Improperly adjusted throttle valve
Bands in need of adjustment
Low fluid levels (leaks)
The infamous gear slamming (caused by switching between D and R too fast)
The rear clutch provides forward motion, its probably worn out.
Needs overhaul to repair.
Thanks
Randy
Reactions: DC-93
Discussion Starter #4
Thanks all..This continually occurs whether warned up or not. A little history..Van sat in field since 1985, has gone to varnish, replaced gas lines, restore going pretty good until... Replaced coolant lines, put about gallon slowly adding over time with the help of leak via couldn't line exit orifice, No burnt fluid . Checked levels going through gears, , going to check linkage. And go from there possibly adjust band s), but I don't think that's the problem... Thanks
KOG
Put shifter in "2", check for engine braking when you close the throttle. If no engine braking it's a rear clutch problem. That's the last part to come out when you take the transmission apart. Have fun.
1 - 5 of 5 Posts
