I recently had my 318 rebuild for mid performance. But, i believe my little 904 isn't quite up to the task. Is there a modern trans (4 or 5 speed) that would work out better? What transmission bolt up to it?
The 904 is a pretty stout piece; you can have them built to handle about anything that a relatively mild 318/360 can throw at it.I recently had my 318 rebuild for mid performance. But, i believe my little 904 isn't quite up to the task. Is there a modern trans (4 or 5 speed) that would work out better? What transmission bolt up to it?
Floor-pan clearance may be a problem. I know the 518 won't fit in A-body cars without major surgery to the floor-pan.a500 or a518
