First item on MH, check the VIN plate, you may find the chassis is anywhere from 1-2 years older than the actual MH year. The incomplete chassis, either as a cutaway (B300) or if the engine is between the front seats under a removable floor section (larger truck or bus chassis, which will have and Mxxx model, Winnebago Braves were like this). There is no ECU, you have the Chrysler electronic ignition, which will have a small box with a heat sink and a large power transistor on it and a ballast resistor. The ballast resistor can be either a single unit or a dual unit depending on the exact year of the chassis.
I used to hate trying to figure out MHs at my shop, you could have a customer with a 1974 Winnebago, yet when you looked at the VIN, the Dodge M400 chassis was built in 1972. MH manufacturers would buy a block of chassis from Chrysler, then build the "house" on them as the market needed them so the chassis can easily be a year or two old when completed.
