Hello all.
I have a problem with my 1975 dodge dart special edition; the engine turns over but their is no spark at all, I have run a check on the entire ignition system and have not found the problem, here is the rundown of what I have done:
1.- Ballast Resistor in working order checked w/multi-meter and is within range.
2.- Ignition Coil- in working order but only receives 6.2 volts from the Ballast resistor.
3.- Replaced the starter relay.
4.- Ignition Module checked.
5.- Pick-up coil at 362 ohms.
6.- Battery is outputting 12.6 volts.
I am at a loss as to how to fix the problem, any help would be greatly appreciated, thanks.
