Look on the passenger's side inside fender or around the passenger's side strut tower under the hood for a module that has both a vacuum line attachment and an electrical plug. I had an 87 LeBaron non-turbo and that is where it was located on that car.geraldg said:where is the map sensor located ?
Hi BobBob Lincoln said:OK.Code 23 - Air charge temperature sensor out of rangeThis is a small thermistor (variable resistor) that is mounted in the throttle body, and it's used only on cold engine starts. It senses the cold air and adds a little extra bit of fuel. There are two wires running to it. Check the wires to be sure it's connected and the connection is clean. If it fails, it should cause no harm.
